1998 Toyota Corolla - Low idle
Old 01-05-05, 09:51 AM
D
doitnewf
when starting when cold, the car idles very low & sometimes stalls.
when it warms it's ok.
Is there some sort of adjustment?
Cheers
John
Old 01-05-05, 02:26 PM
When you start it warm does the idle raise up and then come down to the normal idle?
Old 01-06-05, 10:03 AM
D
doitnewf
No, it seems to just stay at the normal idle.
Thanks
JP
Old 01-06-05, 12:43 PM
Sounds like a bad Idle speed control motor.
Old 01-06-05, 07:07 PM
D
doitnewf
Thanks Larry,
Is it a DIYer kinda job??
How can I check to be sure??
JP
Old 01-06-05, 11:52 PM
I'm trying to send the pages of the manuel.
File Type: pdf
Old 01-06-05, 11:55 PM
If you need the removal of the ISC send me a PM of your email. The file is to large to attach.
Old 01-10-05, 10:06 AM
D
doitnewf
Larry,
I was wrong........ idle does go up then back down when starting warm.
Cheers
John
Old 01-10-05, 11:28 AM
I would try cleaning the Mass air sensor. Here is a link with pictures on how to clean one, scroll down the page a bit and you will see it. It's for a 4x4 but it's the same.
http://www.4x4wire.com/toyota/mainte...tenancep5.html
