01-06-05, 07:11 AM
blindrid
95 Grand Am Starter ?'s
Last PM son's 95 Grand am SE - 4 cyl.. Pulled into garage and starter engaged. Shut it off and started it up and starter would not disengage. I'm guessing it is the starter. Any tips, suggestions on replacing the starter. I'm not even sure where it is located on this car (as to whether or not it's buried or not)? I would like any advice, web sites before I drive up to take a look at it as it might save me a trip or two. Thanks in advance, R
VA
01-06-05, 07:15 AM
starter
it should be located underneath on the left side of the engine block...basically under the intake manifold. not terrible to get to...and for what it's worth...it sounds like the solenoid plunger is sticking, altho it's possible you have a bad ignition switch. the bolts are metric...good luck
