Toyota Transponder key programing
Old 01-06-05, 02:33 PM
darkstarchuck
Does anyone know if I can "on board program" my new aftermarket transponder key to my '03 Sienna XLE ? (I do have one master and I've found several step by step guides) There seems to be some confusion between the different sources online, and I havn't been sucessful following them yet. (as I did w/ the remote fobs!) Just want to make sure it can be done before spending anymore time on it
Thanks for taking the time.
Chuck Jacobi
Old 01-06-05, 03:29 PM
REGISTRATION OF ADDITIONAL MASTER KEY
 It is possible to register up to 7 master key codes including the already registered key code.
Make sure all doors are closed:
Insert already registered master key in the key
cylinder
Depress and release the acceleration pedal 5
times.
Depress and release the brake pedal 6 times,
and remove the master key.
Insert key to be registered in key cylinder.
Depress and release the acceleration pedal 1
time. (Security indicator blinks)
The registration mode completes After 60 sec. The
Security light will go out.
Old 01-06-05, 06:57 PM
darkstarchuck
Perfect, thanks! The other method that was supposed to work was very similar, but not exactly the same.
Old 01-06-05, 07:08 PM
Your Welcome
It is like Simon says.....you have to do exactly as stated...
Old 01-16-05, 07:22 AM
pammyhouse
2004 Transponder programming
I read your message about programming a 2003 Toyota Sienna transponder key.
I have a 2004 Sienna, does the same programming work for it also?
Thanks
Rich
Old 01-16-05, 07:37 AM
Sorry
The 2004 is different and can only be programed with the Toyota Handheld tester. Looks like you will have to go to the Dealer.
Old 01-16-05, 11:30 AM
pammyhouse
Thanks
OK Larry, Thanks for the help. Rich
Old 08-11-06, 07:18 AM
P
Is it possible to program duplicate keys for a 2005 Corolla? If so, what are the steps?
Old 08-11-06, 03:01 PM
welcome back
Welcome back Toyotaman (larry) aint seen you for awhile to give your good advice.
Old 08-11-06, 10:29 PM
davzack's Avatar
You still haven't seen him...this post is over 6 months old.
