No Oil Pressure on Gauge
Old 01-09-05, 04:26 PM
1993 Plymouth Grand voyager. 140,000 miles. Everything I thought was fine and I just changed my own oil and filter and went to start it up the oil pressure does not register anything.
Did I do something wrong or is it just a coincidence that it doesn't show any pressure.
Also could this just be in the gauge? I did check the oil level and it is full.
Thanks for any advice.
Harlan
Old 01-09-05, 04:33 PM
Maybe you knocked the wire off the sender.
Short of that a mechanical gauge would have to be hooked up to verify oil pressure.
Old 01-09-05, 04:57 PM
Would the wire from the sensor be located near the oil filter or is up more in the engine compartment?
Old 01-09-05, 05:04 PM
Very well could be by the oil filter
Old 01-10-05, 05:54 AM
daswede's Avatar
I agree with Toyotaman also.. I might add that you make sure the wire is making good contact. Iv'e had a couple that didn't register till i cleaned up the connector at the sender.
Old 01-10-05, 04:54 PM
I think on that engine the oil pressure sender is next to the oil filter.
Old 01-10-05, 05:44 PM
Thanks
Thanks everyone. It was the oil sensor which was next to the oil filter. I needed to replace it and all works OK.
Thanks again.
Harlan
