Need help with door-1993 GMC Sierra
Old 01-09-05, 06:00 PM
C
Cathyann
Help! It's snowing and cold here. I just went to the store and opened and shut the passenger door after putting in some bags. It worked fine. I got home, took out the bags and now the door won't shut. I don't mean just not tightly. It's as though there were something big blocking it from closing but I don't see anything there. I can't drive to work tomorrow morning like this. Any ideas?
Old 01-09-05, 08:36 PM
joaa's Avatar
Cathyann open the door and see if the latch is allready in the latched position if so use the handle like you were going to open it and with a screw driver pull the latch back into the open position and use wd40 or another water displacement lube to lube it. Hope this helps. Jo
Old 01-10-05, 06:47 AM
C
Cathyann
Thank you so much! I had a restless night and woke up to the dark and cold to try your suggestion. It worked! Thanks so much for the simple and thorough directions and for saving me 2 or more cab fares as well as hours of stress, $ etc.
Old 01-10-05, 02:27 PM
joaa's Avatar
Anytime cathyann, Glad I could be of service. Yell again anytime.
