oil pressure sending unit
Old 01-09-05, 08:07 PM
G
gears2723
Question oil pressure sending unit
how to disconnect electrical sending unit from oil pressure switch on 1996 Stratus 2.5 engine ES. I see a clip on the electrical part. Do I have to push this in to remove, in order to remove Pressure unit? Thanks. I don't want to mess it up
Old 01-10-05, 05:00 PM
C
I'm not sure on that one but if you look closely many connectors have a tab of some sort that you press so you can then pull the connector off. Then they just push back on and the connector clicks in place again.
Some actually have a little plastic piece you pull off first befor you can get it apart. Then you put the plastic retainer back when after you put it back together.
Check Auto Zone's website. They might have a how-to on there.
