93 Aerostar sudden drop in fuel economy
rkooy's Avatar
01-12-05, 08:16 AM   #1
rkooy
My van runs great, no performance problems. Oil pressure, temp, charge, acceleration, all normal. I usually get 650km per 80L fill up. The guage usually barely moves until I drive 150km on a full tank.
With this last fill up, however, I only drove 150 km and the guage is less than 3/4 full. I topped up the tank to verify that the guage is working. The tank took 30 litres!
Any ideas what could be wrong here?
Rob
pgtek's Avatar
CANADA
01-12-05, 10:52 AM   #2
hi
weather factor is one of the effect to cause fuel economy.
the colder it gets the more fuel you will used. same when you fill up the cold has a tendensy to compress the gas flow and u had more guel compare to summer that makes it expands.
cheers
pg
nomind's Avatar
01-12-05, 01:39 PM   #3
hi, -I have the same van and recently noticed similar . I'd think it far more likely that in winter the engine is having to work harder. -longer warm up at first, then powering blower, wipers etc . Much more load on the alternator. Possibly also due for a plug change in my case.
I'd like to hear from some Ford mechanics on this.
Do it Right - Do it once.
nomind's Avatar
01-13-05, 09:33 AM   #4
Hi Ford Guys, -
- we'd appreciate any suggestions for our fuel economy problems.
slickshift's Avatar
01-13-05, 10:36 AM   #5
You are correct nomind and pgtek
Some other things to consider:
O2 sensors getting old and not working as well as they should (I consider them maintainence items not failure items), but not bad enough to "throw a code"
Winter gas in your area-some areas have a winter formula and some engines do not care for it (I had one that dropped over 20% with our "winter gas")
Coolant not up to specs, including thermostat-make sure your engine is not running cold (I have even had summer/winter thermos for vehicles before)
Proper oil viscosity for your climate
These and the previously mentioned items could be conspiring agsinst your gas consumption
Also that vintage EEC-IV computer can store codes and not throw the check engine light so you might wanna pull them/get them read
