Toyota Tacoma 2001 not going into first gear on mornings
Old 01-12-05, 11:21 AM
ddh
Hi
HAppy new year.
I got a 2001 Tacoma V6 3400. When I start the truck on a morning ,and put it into Drive, D, it does not go into first gear. It seems to go into 2nd gear.I have to put the gear stick into L for it to move off. Afterwards,maybe after 5 minutes, I can move the stick into D, and it would work ok and change to all gears. It works normally during the rest of the day.
What should I do?
Thanks
Old 01-12-05, 01:13 PM
Mileage and time of ownership? Service history?
Old 01-12-05, 01:51 PM
ddh
Now 90,000 miles. Purchased used at 80,000 miles.
Should have been well serviced by previous owner. Transmission shows after-market sealant used like silicone (on the outside) . Should there have been a gasket.?
I suspect possible previous transmission issues, but worked ok for the last 6 months.
Alternatively, should there be an automatic choke that heats up the engine at the first crank in the morning?
Old 01-12-05, 02:18 PM
Sounds like a valve sticking in the valve body.
Maybe a fluid change may help? Not a believer of mechanic in a can but if you drop the pan and there is no metal or debris I would add a can of Lube-guard with the fluid.
There is no gasket the Toyota FIPG should be orange.
