cigarette lighter not working-1993 GMC pickup Sierra
Cathyann's Avatar
01-12-05, 08:28 PM   #1
Cathyann
I want to use an air pump that is powerd by using an adapter for the cigarette lighter. The cigarette lighter won't work either with the pump or to light the hand held element. Is this form a burnt fuse and if so where would I check to see and replace if necessary? Or is it something else?
the_tow_guy's Avatar
FL
01-13-05, 04:43 AM   #2
The cigarette lighter will be on a fuse either by itself or possibly with something small like the domelight. Should be clearly marked in your fuse panel. Also check that the wire(s) to the back of the socket are properly connected. Most lighter receptacles pull out fairly easily to check and you can also buy a replacement one at most auto stores; its a pretty generic item.
Measure it with a micrometer; cut it with an ax.
daswede's Avatar
MA
01-13-05, 04:19 PM   #3
Did you try it with the key on? not start position though.
