79 Ford E-150
Old 01-15-05, 11:05 AM
vandriver
79 Ford E-150
The problem with the van is it does not want to start if it is raining or foggy outside. Once running, moisture has no effect on it for the remainder of the day. Also, sometimes you can be driving and it will shut off by itself or if you shut it off you will have to wait around two hours before it will start again no matter the weather condition. I have changed the module, plugs, plug wires, distributer cap, rotary cap, ignition switch, and coil. Do you have any idea what the problem might be? If you can help me it will be greatly apreciated. Thanks.
Old 01-16-05, 04:16 AM
hogfan's Avatar
I think the problem is going to be in the ignition system, sounds like a MODULE
but could also be the PICK UP COIL in the distributor.
