Heater not blowing
Old 01-16-05, 10:25 AM
macbail
Heater not blowing
The vehicle in question is a 1993 Lumina 3.1, the heater has hot air, but no speeds, before if you gave a little boot under the dash it would come on, now it doesn't. I figure the blower is probably gone, but my question is, how hard is this to change? Can I do this myself?
Also I have a 1990 Chev Silverado, with sort of the same problem, I have heat but only one speed on the switch, which is high, could this just be the switch?
Old 01-16-05, 02:37 PM
D
On the Lumina check for power at the blower motor before condemning it.The truck sounds like it needs a blower motor resistor.
