How difficult to change a master cylinder?
rbecklan's Avatar
01-16-05, 09:32 AM   #1
rbecklan
Does anyone know how difficult it is to change a master cylinder? I don't have any experience with mechanics but I will have a repair manual. Should I attempt it myself, or take it to an expert?
michael van's Avatar
TX
01-16-05, 09:44 AM   #2
type car
What kind of car? clutch or brake?Pretty easy on most cars.
the_tow_guy's Avatar
FL
01-16-05, 10:24 AM   #3
Just follow the directions closely. There should be instructions with the new part for bench bleeding prior to installation. Pay close attention to this procedure, it is absolutely essential.
Measure it with a micrometer; cut it with an ax.
TX
01-16-05, 10:30 AM   #4
Tools
Also do yourself a favor get some proper flare nut wrenches so you do not round off the fittings.
square 1's Avatar
01-16-05, 12:52 PM   #5
In addition to the other posts, I would add that if your talking brakes and your car is non ABS you should be fine. But, since you say you are not mechanical, If your car does have ABS brakes, go directly to a professional. Good luck
Desi501's Avatar
01-16-05, 05:28 PM   #6
It's not a difficult repair from a technician's point of view but it does have a lot of potential for problems if your doing this for the first time. Anything from damaging fittings or threads to not being able to get a brake pedal back.
