89 toyota van-won't go into overdrive
Old 01-17-05, 01:30 PM
fastrepair
230k miles. replaced transmission relay and the overdrive silinoid on the trans, with used parts from junkyard.
still won't go into o/d.
please help.
Old 01-17-05, 02:41 PM
First thing to check is the engine temp guage going almost to the middle? Stuck or no thermostat will prevent OD shift.
Old 01-17-05, 04:00 PM
fastrepair
The temp gage does not reach the mid point. it stays half way between cold and mid point.
should i replace the thermostat?
if so, what temp? 160 or 180?
Thanks Larry
Old 01-17-05, 04:23 PM
The OEM is 88c which is 190f. That 1/4 of the way on the guage is close to where it should engage OD but might be a little shy.
Proper reading should be about 3/8 or almost 1/2.
Old 01-19-05, 10:31 AM
fastrepair
thank you, I will replace thermostat next wk-end and i'll post a report.
Old 02-02-05, 01:43 PM
fastrepair
replaced thermostat
I replaced the thermostat. the temp is close to mid point on the guage.
but still won't go into overdrive.
what else could it be?
is there a temp switch?
thanks
Old 02-07-05, 10:55 AM
fastrepair
Any ideas? anyone?
thanks
Old 03-08-05, 09:31 PM
fastrepair
This Site Is Good For Nothing!!!
The "master Tech" Never Answered.
Old 03-08-05, 11:13 PM
I'm sorry
Why don't you drop it off to my house and I'll fix it for you.
BTW: I did try to help you, it's a little hard when I no longer have any info for a '89 Van. We don't maintain an archive of manuels for all the old stuff.
