89 Toyota 4x4 pickup idling very fast
Old 01-18-05, 09:41 AM
Seadragon
I just recently purchased a 1989 Toyota 4x4 pickup. It idles very fast (sounds the same as running 50 down the highway). I noticed today that the temp gauge doesn't get off the cold mark and the upper radiator hose is just bearly warm after driving it for two hours. I think the thermostat might be stuck open or possibly non existant. It's a four cylinder EFI engine. Would the engine running cooler than it should cause the increase in idle speed? Or am I crazy for thinking that way?
Old 01-18-05, 12:49 PM
Master101
Might be Aux. Air Valve (AAV) under the throttle body is stuck open. Might have to replace it.
Old 01-18-05, 01:23 PM
joaa's Avatar
Check for vacuum leaks and replace the thermostat anyway it should run better warmed up besides more efficiently.
Old 01-18-05, 04:31 PM
The aux air valve needs to see normal operating temp to close (so idle returns to normal). You don't have that so the idle is at the cold spec (fast).
So you need to replace the thermo with the correct one (190*)
Old 01-19-05, 04:06 AM
Seadragon
Thanks folks, I really surprised I managed to connect the engine temp with the idle . Now, I just hope that this si all that is wrong
Old 01-19-05, 05:56 AM
Just make sure you get all the air out. When you add the antifreeze run it with the cap off and vary the rpm till it's good and hot.
Old 01-19-05, 03:42 PM
Seadragon
Thank you very much! The Thermostat was stuck open. The new is in, and the truck warmed up and idled down nicely! thanks again.
Old 01-19-05, 06:55 PM
Good work!
