removing auto decals
Paulypfunk's Avatar
01-18-05, 10:35 AM   #1
I just bought an old fleet vehicle and I want to remove the remenants of the painted on telephone numbers and the adhesive decals that have been on there for years and years. Is their a product I can use that will work without removing the underlying factory paint job?
pgtek's Avatar
CANADA
01-18-05, 10:50 AM   #2
hi
peel of one corner and spray wd-40 to ease removing
cheers
pg
Paulypfunk's Avatar
01-18-05, 11:11 AM   #3
What about the portion that has been painted on?
goldstar's Avatar
OH
01-18-05, 11:34 AM   #4
I would suspect that the areas under the decals have not been sun faded over the " years and years". Removing the decals will leave shadow marks. I think a cheap repaint may be the easiest out.
GregH's Avatar
Super Moderator
CANADA
01-18-05, 11:56 AM   #5
A heat gun to gently heat the decals should remove them quite easily.
I have removed painted lettering by wiping with oven cleaner sprayed on a dampened rag.
This will affect the paint but the lettering usually "gives" first.
Some types of lettering are harder to remove and a repaint or judiciously applied decal will cover what you want to hide.
Hey, maybe you can have the RoadRunner and Wiley Coyote like you always wanted.
GregH.........HVAC/R Tech
