90 Chevy Astro AWD
chevyastro4x4's Avatar
SD
01-19-05, 06:45 PM   #1
90 Chevy Astro AWD
I was changing the air filter one day, and i took the power steering container off so i could get to the air filter and the bunch of wire behide the power steering container, 3 of the tubes with those bunch of wires got cracked and now my climate control don't work, its always on defrost and theres 2 plastic tubes on one side and only one on the other. are all 3 of those little black tubes suppose to be togeather or just 2 HELP if anyone knows what tubes im talking about.
joaa's Avatar
IA
01-19-05, 09:05 PM   #2
Lacking vacuum to the switch sets the diverter gate to defrost. You need to splice those tubes with a small rubber hose. Don't push the hoses on to far so if you get them on wrong you can change them around. Good luck.
SD
01-20-05, 04:28 AM   #3
do all three of the tubes have to be together? or just 2
thanks
davo's Avatar
01-20-05, 03:36 PM   #4
I don't remember any joining of 3 maybe there is a 4th you are not seeing.But I only remember the 1 plastic hose.Could you email me a pic of the hoses?If so I may be able to direct you better.
SD
01-20-05, 05:18 PM   #5
sorry i dont have a camera, on the drivers side there are 2 little black plastic tubes sided by side and on the passneger side theres only 1 black plastic tube, i'll try and connect one of them see if it works. ill you know if it does 2morrow, thanks for everyones help.
SD
01-21-05, 03:03 PM   #6
thanks for everyones help i got it fixed today
