96 GMC Safari Heat Controler
chevyastro4x4's Avatar
SD
01-21-05, 05:08 PM   #1
My mom has a 96 GMC Safari and when you switch the heat thing for the differnet vents and ac. when you turn that it doesnt change the setting, it doesnt even make a noise from the air going to thought the knob.
Any ideas what could be up with it.
davo's Avatar
01-22-05, 04:20 AM   #2
Looking from under the hood you should find a broken plastic line near the front of the intake.That is the most common problem.You may have to remove the inside cover to repair the line,a small piece of vacuum hose works well.
