91 Hnd Acd 2.1L Auto
Old 01-24-05, 12:37 PM
Question 91 Hnd Acd 2.1L Auto
I have a fuel consuption issue with my honda. From a stop my idle is a bit eratic and when I put in drive I notice a whitish/clear cloud coming from the exhaust. I know what causes a dark blue or black cloud but not this type. And when engine is first warmed up check engine light is not on but when I start to drive and the engine is up to around 2500rpm's there's a dragging feeling but it stops and check engine light comes on and it drives fine. I haven't a clue what the problem is. Thank you for the help.
Old 01-24-05, 03:09 PM
the_tow_guy's Avatar
White smoke after the engine is up to temperature would be from an internal coolant/water leak; possible head gasket failing. Do you have to add coolant or water fairly frequently? Possibly getting a check engine light because of the water/coolant in the exhaust stream affecting the o2 sensor. Going to probably need to have it professionally checked.
Old 01-24-05, 03:21 PM
Thanks for the reply. I have noticed the coolant level low. I just changed oil myself and didn't see water in oil. Wouldn't a bad head gasket allow water to mix with oil too?
Old 01-24-05, 06:16 PM
A bad head gasket or cracked head could let coolant into the combustion chamber which would go out the exhaust with out getting a significant amount of coolant into the oil.
Old 01-25-05, 04:22 AM
Right. Depends on exactly where on the gasket itself the bad spot is as to whether it leaks the coolant into the crankcase or into the cylinder to be burned. You're probably looking at a head gasket job and I wouldn't be surprised if your head is a little warped (ummm, sorry, the CYLINDER head). Make sure the head is checked at a machine shop if you do the gasket or have it done at a garage. And since it's a Honda, how old is the timing belt? Would be a good time to replace it.
Old 01-25-05, 08:49 AM
I will probably replace head gasket myself and take the head to get rebuilt. Might as well since I have it pulled out. Before I do that I should do a compression test on each cylinder, right? Thanks for the advice.
Old 01-25-05, 07:13 PM
Not much point unless you need the practice. What you'll find is low compression on at least one cylinder, possibly two if the gasket failed between cylinders.
Old 01-26-05, 08:58 AM
I inspected the cap/rotor & wires and replaced them all and the white smoke cloud has gone away and my fuel consumption issue has too. Could have this been the problem? Check engine light still on though. Thanks
Old 01-26-05, 03:43 PM
Could be you were mistaking the color of the "smoke"?
Old 01-27-05, 08:49 AM
But that doesn't explain the water lose. I should probably have a compression test done anyway, right?
Old 01-27-05, 11:47 AM
Yes, since there's some question on the condition of the engine that would be a good place to start. First off, you might pull the plugs and inspect them. Spark plugs operating in a cylinder that is burning water/coolant are often much cleaner, i.e. white rather than slightly sooty, than the other plugs.
Old 01-27-05, 04:46 PM
Desi501's Avatar
Not a compression test but a cooling system pressure test to find that problem.
Old 01-28-05, 04:59 AM
Just slap me; should have said that.
Old 01-28-05, 01:00 PM
Thanks again for the help.
Old 02-02-05, 11:50 AM
Did Compression test and all cylinders are good and in that process i found coolant leak. It was the 0-ring gasket that connects upper radiator hose to head. I have another Question for you now: My head lights are really dim. I checked voltage at battery it read 12v plus and I checked with car running and altenator is charging the batt read 14 plus. Could it be the blubs that are bad? Thanks
Old 02-02-05, 09:06 PM
z999
Sounds high ; have the alternator checked at an auto electrcian.
The coolant loss may be not related to the head gasket at all, more likely not in fact. Could be hoses, radiator or radiator cap. (I've just looked back in the thread - wasn't head)
A car that old could easily have a leaking head gasket and worn rings which would give you a little bit of white smoke.
Old 02-02-05, 09:43 PM
The voltage is within specs
Are they dim all the time?
Or just at idle?
Probably not the bulbs btw, and many places will check the charging system (batt. alt.) at no charge...um...for free
