88 4Runner ignition module/switch
Negoshe8n's Avatar
01-30-05, 01:44 PM   #1
Negoshe8n
I have a good starter, great battery, and nothing as I turn the key. I suspect that it is the switch. Is this just behind the key cylinder? What is involved with this repair? Thanks
toyotaman11769's Avatar
01-30-05, 01:58 PM   #2
Is it a stick or auto?
What about any aftermarket alarms or remains of?
Negoshe8n's Avatar
01-30-05, 02:03 PM   #3
Negoshe8n
stick, no alarm,
01-30-05, 02:14 PM   #4
You could have a problem with the clutch switch, does it have a bypass switch on the dash?
How do you know the starter is good?
Negoshe8n's Avatar
01-30-05, 07:30 PM   #5
Negoshe8n
This is a friends truck. I was only told of the problem after the starter was pulled. I just had the starter checked at the store. It engauged and spun. So after I installed the same starter, I myself turned the key. The starter clicks but doesn't engauge or spin. So it can't be the ignition switch. I'm going to just install a new starter tomorrow and hope that is the problem. The truck just wouldn't start the next morning so it shouldn't have seized. It had oil pressure, oil, and a good antifreeze mix. It just doesn't have the juice to turn the motor over. I can raise and lower the rear glass with the switch, so I know the battery has plenty of power. I will swap out the battery just for good measure before doing the starter install. Thanks for the help.
01-31-05, 02:35 AM   #6
A little confusing
Checking the battery by using the rear window is a new test for me. I think the battery needs to be on a battery tester to properly diagnose.
Did you replace the starter and still have a problem?
