93 Lincoln Stalls
Dreamanddo's Avatar
01-31-05, 09:10 PM   #1
Dreamanddo
93 Lincoln Stalls
My daughter's 93 Continental 3.8 ltr fuel injected v6 stalls after a few minutes of driving and will not start after. It may have multiple problems cause the fuel pump wasn't working so we swapped it out. It drove fine for a day (she doesn't drive too far) but stalled out again this evening. I took her to her house and came back to check out the car (20 minutes) and it started right up. On the way to my house (3 minute drive) and it stalled on the way and would not start though I could here the fuel punmp working. I've also check the air filter and the spark.
the_tow_guy's Avatar
FL
02-01-05, 09:25 AM   #2
Did you by any chance also change the fuel filter? Just a thought.
Measure it with a micrometer; cut it with an ax.
davo's Avatar
02-01-05, 04:18 PM   #3
If you have checked fuel pressure not pump noise and have checked for spark at more than 1 plug wire it's time to check for injector pulse with a noid light.It sounds as if you may have a failing crank sensor but you need to do those checks first.
