Check engine light
Check engine light
I have a 2000 Ford Focus with approx 90,000 miles. When I accelerate, it seems that something is stopping the engine from accerrating properly. I have changed the spark plugs, the fuel pump is new, and the fuel filter is semi-new. About a month ago my engine light came on, and they said it was for the EMS canister. They reset the light, but it came back on tonight. I haven't changed the canister yet--could that be the cause of the hesitation with the acceleration? Help!!!
It would be much better if you posted the code retrieved rather than someones definition of the code (I haven't the foggiest idea what an EMS cannister is but I would expect to find it in the back of an ambulance).
There was a recall for the fuel pump modules that may include your car.... you can either check with your dealer (take your VIN and have them run OASIS on it) or post your VIN here and I can do it for you...
I'm guessing that it's in reference to the charcoal cannister for the evap system, but the actual codes would be helpful. The EMS abbreviation is a little odd.
Question: When you get gas, do you routinely squeeze extra gas in beyond when the pump kicks off?
Hardly a trip goes by at the gas station (a daily visit) that I don't hear the telltale "chnk...chnk...chnk" of someone on an adjacent pump filling that baby up until they can see fuel in the filler neck. It's a wonder there aren't more dead cars from it.
I had a similar problem with my car and the problem was the oxygen sensor. It took two trips to the mechanic to find this out. Not sure why it was not diagnosed right the first time, but figured I would bring it up. Good luck.
