97 F250 solenoid
mexican163's Avatar
02-01-05, 10:58 AM   #1
97 F250 solenoid
Lately when I start it, sometimes it goes clunk. There is power to everything (headlights, radio) then I wait a while and try a few times and it starts. So, I replace it. Then the next week it does it again, I take it to get the electrical system checked and they said all ok. Next day goes clunk again. It is the solenoid cause I had friend try to start it while I listen under hood and on the fender it goes clunk. I call them and they say those solenoid are problematic and should purchase more expensive one or have extras on hand. Does anyone know of this??? Is there something else that could cause this problem or the solenoid to go bad repeatedly??? Had truck for 4 months and just started this last week. Thanks.
billys68ss's Avatar
WV
02-02-05, 04:30 PM   #2
You could have a bad solenoid. Or you could have a loose or bad ground connection. I have seen all of the above. The first thing I would do is remove the solenoid and clean the fender where it was bolted on. Make sure when you reattach the solenoid that the screws are good and tight. You want the best possible contact here because this is your ground. Make sure all of the connections on the solenoid are tight as well.
Hope this is helpful to ya,
Billy
