94 CHEVY S10 please Help a girl out!!
94 Chevy S10.....girl Thanx Responders.. Big Help
undefinedundefined
I have an S10 and I have my starter loose and disconnected... It will NOT come out!!!!!!!!!!!!!!!!!!!!!!!!!!! HELP!!!! It is a 4.3 and starter is under passenger side wheel..... xxxxxx@xxxx.com
I have a Haynes book on the Chevy S-10 & GMC Sonoma, but it is at home. I will see what it says about your starter removal on the 4.3L later today and let you know if any further disassembly is needed. Don't bother with the tranny or exhaust system yet, I don't believe they are going to do it.
Question - Is it indeed a 4-wheel drive truck?
I have done recent repairs to a 1995 S-10 that my daughter uses (head gasket, clutch, alternator), but that is a 2-wheel drive 2.2L 4-cylinder truck. Even with the smaller engine, there is hardly any room to work on anything.
A useful forum for the Chevy S-10 truck is: mys10.com
From the Haynes Manual (covering S-!0 and Sonoma trucks from 1994 to 2001):
Starter Motor - removal and installation
4WD Models
Disconnect negative battery cable (always for a starter).
Raise front of vehicle, support on jackstands.
Remove right wheel (on 4.3L models) for better access.
Remove skid plate if present.
On some early models, it may be necessary to raise the engine/transmission with a floorjack under the trans, remove transmission crossmember for access to starter bolts.
Remove starter heat shield, if so equipped.
From under vehicle, disconnect solenoid wire and battery cable from terminals on the solenoid.
Remove the starter mounting bolts.
Remove starter motor (sounds easy enough!). Note the location of any spacer shims.
During re-install, be sure to install the spacer shims in exactly the same location.
It sounds like the raising of the trans, and removal of crossmember allows for easier removal once the bolts are out.
I hope this helps you out.
4WD Models
