89 ISUZU Pick-up w/Manual Trans, 150k
Old 02-12-05, 12:23 AM
R
roaddog
Question 89 ISUZU Pick-up w/Manual Trans, 150k
The indicator lights on my dashboard that normally light up when the starter is being egaged do not go out when I let go of the key. They remain on for 4-10 minutes. Also, while the Indicator lights are on, the Heater Blower Motor will not work. Once the lights go out, the Blower works fine. Fuses, relays, and ignition switch are good. Any idea what might be causing this problem?
Thx Much
Old 02-12-05, 04:18 AM
Sounds like the ignition sw, try moving the key back and forth while the lights are on.
