2000 Camry Visor Mirror Replacement
Old 02-12-05, 08:44 AM
sliderbot
I have a 2000 Camry LE and the hinge on the visor mirror has broken. This frame is held in by two clips, and can be removed. However, it appears that Toyota only sells the visor as a whole, no parts unless you have the XLE and need a replacement lighted mirror. Used parts are scarce, so I am looking for aftermarker sources or to find out whether the XLE lighted mirror will slide into the same spot. With the latter, I presume the light is powered by the car's 12v and not batteries, so I am also not sure whether there is a connection in the LE for it.
Old 02-12-05, 11:44 AM
I don't know of an aftermarket supplier of Toyota visors. The wires are not there if it didn't have lighted mirrors.
Old 02-13-05, 11:39 AM
You might try doing a search for a used visor at www.car-part.com and look under "Interior Panels/Misc" and there are some visors listed throughout the multiple pages.
