Audi front turn signal...should be easy??
Old 02-12-05, 04:50 PM
G
Can you explain how to replace the right front turn signal bulb in this 1990 Audi 80? Can the lens be removed from the front, or do all of the components behind (under the hood) need moved out of the way to work from behind?
Old 02-13-05, 07:13 AM
billys68ss's Avatar
You can only change the turn signal bulb after removing the headlamp to gain access. I dont have detailed instructions so unfortunatly you are on your own there.
Hope this helps ya,
Billy
Old 02-15-05, 07:42 AM
G
Gotcha.....
I'll give that a try and see what happens.
Old 02-15-05, 12:59 PM
daswede's Avatar
Logon to the 'autozone'web site . they just might have a 'how to' diagram and instructions for your car. Did for my ford.
