Headlights-high beams work but low beams don't
I wont comment too much on the "exhorbitant price" idea other than to say if they fix it, what's exhorbitant.
Can't speak for the APV but I have seen pick-ups with faulty multifunction switches and even burned wiring at the multifunction switch. IIRC, you should be able to access the switch to inspect it and the wiring by removing the steering column garnish... 3 or 4 screws and the upper and lower halves should separate. You may have to remove the tilt lever and/or the ignition lock cylinder to comlete the process.
