'99 Pontiac Grand Prix GT
Old 02-14-05, 06:26 AM
hagglerock
I could use some help with two items:
1. The blower does not work on speed 1 (lowest) is this a faulty switch or the resistor. How can I touble shoot the problem.
2. The light in the steering wheel volume control switch is out. I assume this is a sealed unit and I will have to replace the switch assembly. How do you remove the switch assembly.
Thank-You in advance for any help you may be able to offer
Old 02-14-05, 02:25 PM
Take a test lamp and probe the connector ar the resistor(disconnect it)with the key on operate the switch in all positions checking for the lamp to illuminate.The steering wheel controls are a tough one you will need a small screwdriver to pop it out then disconnect the connector,plug the connector into the new switch and push it back in until firmly seated.
Trackbacks are On
Pingbacks are On
Refbacks are On
