92 T&C Brakes
Old 02-16-05, 12:20 PM
wiltay
92 T&C Brakes
I change my front brakes and now I'm getting a hard pedle, What is wrong.
Old 02-16-05, 03:41 PM
Does the vehicle stop properly?Please be a little more descriptive about your problem and I will try to help.
Old 02-16-05, 03:47 PM
New guy's Avatar
When you said "hard pedal", do you mean something like pushing hard on the pedal(stand on it) to makes it stop or the pedal feel "spongy" and it does not stop well?. If the later, the pads does not seats right onto the rotors due to the rust protecting on the pads surfaces and or the rotors need to be resurface.
Old 02-17-05, 08:44 AM
wiltay
No the van does not stop you have to push (stand on it ) to stop the van.
Old 02-17-05, 09:16 AM
New guy's Avatar
Make sure your brake hoses are straight, you might "kinked" it when reinstalled calipers.
Old 02-17-05, 02:57 PM
billys68ss's Avatar
Sounds like a booster problem. Did you disconnect the vacuum line for any reason? Did you force the the pistons into the calipers very fast?
Billy
Old 02-20-05, 05:45 PM
wiltay
I did not think that I push it in to fast and I did not remove the hose I think I can check. Is it easy to replace a boster??
