Cap cover sticking
Cap cover sticking
2003 Hyundai Accent.When i try to pull the lever on the floor the gas cap cover will not release.How do I fix it?
Could be a stretched/dirty/damaged cable, a dirty/damaged latch or binding hinge mechanism. All three areas bear close inspection. Perhaps someone familiar with Hyundai could let you know if there are any "pattern" failures.
Some cars have an emergency release in the trunk. It's worth a check before you run dry. Look near the gas door on the inside. It may even be behind a panel.
try this
Two people required while you pull handle in car have other person push in a little on cover for cap.
Noticed last night if I go back and pull out on the cover,it will move a little bit,then go back and pull up the lever it will open up every time.Could this be a stretched cable already and Do they have an ajuster on them somewhere?
Try a little WD-40 on the locking mechanism and hinge.
lube it
with cover open move cable and see if latch moves full throw.Then lube up with wd-40.
I do not think any adjustment is possible.
Previous Thread
Next Thread
