Ford Transmission
Old 02-21-05, 03:35 PM
walleye
Ford Transmission
1999 Ford Ranger 4x4 The High And Low Four Wheeldrive Lights
Blink On And Off When Driving. When This Happens When I Turn The 4
Wheel Drive On Nothing Happens. I Had The Switch Changed In The Dash And Did Not Do Anything. However The Mech. Jumped The Motor
For The 4 Wheel Drive And This Works.
Walleye
Old 02-21-05, 04:46 PM
You'll need to have the codes read and post them here... someone should be able to help.
Old 02-23-05, 04:22 PM
walleye
ford transmission
I Assume This Is The Same As When You Get A Check Engine Light
And The Mech. Checks It With His Equip. For A Short Time The Check Engine Light Was On. I Had I Tune Up Done And The Light Went Away.
Then Two Weeks Latter It Came Back On And I Had It Check Again
And I Was Told Is Was Evaporater Cannister Loss. I Was The Told
That This Was A Loose Gas Cap. I Was Having Ths Same Problems
With The High And Low Lights Blinking. The Check Engine Light
Went Off After I Dissconected The Battery But The Transmission
Lights Still Blink.
