moisture in headlamp
Old 02-21-05, 04:41 PM
OHKP55's Avatar
I have a 2000 Dodge Intrepid. The right headlamp assembly is "weeping". A lot of moisture is inside the assembly, but it isn't poolong yet. Short of sheeling out $250+ for a new assembly, and that's from a salvage yard, is there a way to seal off the housing and stop the moisture buildup?
Old 02-21-05, 05:21 PM
New guy's Avatar
Instead of try to reseal the housing, how about drilling couple holes (1/8 ")on the bottom of the lamp for it drain out and save a few bucks. Do not reseal the drain holes.
Old 03-04-05, 05:25 PM
OHKP55's Avatar
headlamp moisture
Actually I did that on my wife's old Caravan. Worked fine but I thought I'd check and see if there anythng better.
