NEED HELP>>interior vent steam....safe to drive?
jerjr101's Avatar
02-22-05, 09:24 PM   #1
jerjr101
I have a 93 Olds Achieva that started blowing a lot of steam out of the dash vents and noticed that the heater is not producing any heat! I checked the coolant level and it was very low. I added about a gallon of liquid and started the car to see if that changed anything. After turning the car off i heard liquid flowing from the rear of the engine near the firewall. Not sure what it is, and I dont know if it should be driven or not?
mechanic's Avatar
02-22-05, 10:25 PM   #2
A resounding NO.... the leak should be diagnosed and repaired before you drive the car any more.... If you continue to operate the car, I can see a new motor in your future.
michael van's Avatar
TX
02-23-05, 05:23 AM   #3
No and no
No dont drive you are losing coolant sounds like a heater core problem not a fun thing to fix.If you overheat car you are looking at other problems like warped heads at the least.
If it is the heater core it is possible or it used to be on older cars to bypass it with a hose.But then you would have no heater.
scan's Avatar
02-24-05, 11:09 AM   #4
scan
Fumes Too
And the fumes from ethelyne glycol antifreeze are toxic
If you check with your hands, the carpeting in the front footwells is probably wet and sweet smelling
Sorry, but this is a big problem probably with a big repair bill
joatmon's Avatar
03-07-05, 03:03 PM   #5
Agreed. Most likely a blown heater core. And aside from replacing a head gasket, it's probably the only other coolant related repair job, I won't tackle myself. There's usually too much labor involved, ripping your entire dash apart to get to the core. Last time I had one blow, I think it was a couple hundred bucks to let someone else have the headache.
