93 Bonny window motor
Old 02-25-05, 01:25 PM
jrw_sound
93 Pontiac Bonneville SSE w/power everything.
My driver side window won't go up or down but the rest of them do. Could this be anything besides the motor in the door? When I try to make it work all I hear is a single "click".
Will it be hard to access the window motor on this vehicle?
Thanks.
Old 02-25-05, 02:21 PM
Where is the click coming from? The switch, a normal click it makes, or from inside the door as in the motor clicking? It could be a bad switch. Check for voltage at the motor when operating the switch. You can find directions on replacing the motor in a Haynes manual or maybe www.autozone.com.
Someone else here may know if its easy access.
Old 02-26-05, 07:17 AM
jrw_sound
The clicking is definitely coming from within the door, not the switch itself. I'll check a manual out.
I was just wondering if there might be a relay or something else associated with the motor that I might need to know about.
Thanks for responding Jeff.
