Jaguar
Jaguar
Right rear power window will not come down. Hear a click when switch is pushed, but no window movement. Have tried running a putty knife around window to see if it is stuck with no luck. Thanks for any suggestions.
What model/year is it?. If you can get accesss to the window motor by removing the door panel and give it a tap on the motor with screwdriver handle while holding the switch on the down position and see if it works.
