Stereo Static
JMorales07's Avatar
02-26-05, 05:06 PM   #1
JMorales07
Stereo Static
I have a 1993 S-10 Blazer and am having some problems with my Stereo. I recently had a Pioneer A-M FM CD player installed and it plays CD's fine, and the radio portion works fine when the engine is off. Once you start the vehicle I get static on the radio only, the CD plays and sounds well. I took it back to the shop and they said it was the radio, and installed a new Clarion at no charge but the same problem. Any thoughts?
hogfan's Avatar
02-27-05, 07:48 PM   #2
Check the ground circuit on the radio installed.Try an antenna,if problem is still there than check the ignition system such as spark plugs,spark wires,cap and rotor. Solid core spark plug wires will do this. Non resistor spark plugs also. Charging systems can sometimes cause interference.
