Chevy Cavalier Trannny dip stick
Old 02-27-05, 09:04 PM
hornetman
I recently purchased a 2002 Chevrolet Cavalier 4 Cyl. In checking the fluid levels I found a cap over the driver side tranny well. Unscrew thw cap and I see a cable passing through the reservoir. The reservoir looks like a bottomless pit. Ther is no dip stick. How can a normal sane individual check the fluid level and ensure enough fluid is present?
Old 02-28-05, 04:25 AM
You start the car warm the engine and shift through all the gears stopping in each one for several seconds.You the raise the car on a hoist or four jackstands and remove the plug towards the convertor side of the transmission.The fluid level should be even with the bottom of the hole.The engine must remain running during the procedure and not shut off until the plug is replaced.
Old 03-02-05, 06:29 PM
Thank you General Motors---what a GREAT design!
Old 03-03-05, 09:10 AM
chevyastro4x4's Avatar
thats werid because mine has a dipstick
96 Chevy Cavalier
Old 03-03-05, 01:37 PM
Actually it is because unless you have a leak it shouldn't be a big deal.You have to get under the car to change the fluid and the method used prevents overfilling the transmission.If you have a leak it needs fixed anyhow so it is a good design.
Old 03-04-05, 07:38 AM
Ya it is a good design.
