sensor location
Old 03-02-05, 10:47 AM
1grncapri
sensor location
HELP! Does anyone know the locatoin of the cam sensor in a F-150 FORD w/4.0 V6 THANKS!
Old 03-02-05, 01:54 PM
The year of the truck may help.Are you sure you have a F-150 with a 4.0 v-6 because I have never seen one.If you have a 4.0 it's mounted on top of the oil pump drive near the back of the engine.Only certain years have them.
Old 03-03-05, 06:19 AM
1grncapri
rejection sticker
i have a 96 f-150 with a 4.9 six bank 1 and bank 2 to lean
codes are p0175 and p0171. i changed all 3 oxygen sensors and check engine still comes on. truck did not pass emissions.
i also have a 97 f-150 with a 4.2 liter v - 6 engine codes are bank 1,and
cam shaft sensor,can you tell me where they are so i can change them.
truck hesitataes on take off from stop,but runs good after that.
thanks for your help,maybe i should buy gmc .
Old 03-04-05, 03:51 AM
Desi501's Avatar
Just because a codes says something is wrong with the info from a sensor, doesn't mean the sensor is bad. The circuit needs to be trouble shooted. In the case of the O/2 sensors, the code says they are reporting too lean. Why does that mean the sensor is bad. Maybe your engine really IS too lean. Look for vacuum leaks or other causes of too lean a mixture. On a ford, the cam sensor is usually where the distributer used to be.
Old 03-04-05, 04:15 AM
You should check fuel pressure when you ahve lean codes also and perhaps clean the MAF sensor inside with brake cleaner spray.If the code is for bank 1 on the other truck you need to look harder on the side of the engine with #1 cylinder because that's bank 1.An exhaust leak before the O2 sensor can set a lean code also.
