brake light, speedometer
Old 03-07-05, 09:07 AM
marcof3
The brake light and abs lights cam on on my 1999 Dodge 1500 pickup. The speedometer spoted working at the same time. The speedometer will start working when I reach a speed of around 65 mph. I have changed the speed control sensor on the transmission. This didn't fix the problem. What else could it be? Any help will be appreciated.
Old 03-11-05, 12:55 PM
marcof3
bad sensor?
Could it be possible that the new sensor is bad? Is there any way to check the sensors to see if they are good? thanks
Old 03-11-05, 08:45 PM
Old 03-31-05, 06:03 PM
marcof3
Thanks Jeff, I ordered the part (rear speed sensor) after checking out the site you pointed me to. It took about two weeks to get it but once I got it and replaced the old one my truck was fine. So advice to others who might have the same problem...replace both the speed sensor on the transmission and the one on the rear differential. Again,thanks a lot Jeff.
Trackbacks are On
Pingbacks are On
Refbacks are On
