03-10-05, 05:55 PM
ERG Flow Insufficient on 96 Expedition
The Check Engine light came on. I had the code read at Advance Auto. Code was P0401 which was translated into "ERG Flow Insufficient" I have a HAYNES REPAIR MANUAL to guide me. Do you have any advice before I go "sucking on Vacuum tubes"
Thanks
John
Thanks
John
Non-US
03-10-05, 06:41 PM
Pull vacuum on the EGR valve while vehicle is running. Does vehicle try to die? If so problem is more likely going to be a DPFE SENSOR. If RPM's of the engine does not change much with vacuum on EGR valve than remove the upper intake manifold and clean the EGR ports out. Remove the EGR valve to gain access.
