Honda Accord front rotor r/r
I have a 92 Honda accord and i am trying to replace the front rotors I removed the caliper. pads. caliper mounting bracket. axle nut. lower ball joint from spindle. removed the four bolts from the inside of the hub. I hit the rotor and the hub came out of the bearing instead of the hole assy. I changed the rotor and reassembeled Will this be ok? I was told the bearing will go soon.
Any advice will be appreciated Thank you.
You didn't need to do any more than remove the caliper and (depending on the assembly) the caliper mounting bracket. The rotor would have come off. The person is right, now that the bearing has come out of it's sealed unit, it will fail...quickly. Replace it before you end up losing the wheel.
