95 chevy lumina apv timing belt replacement?
Old 03-14-05, 08:07 AM
kb9lfr
What's the recommended frequency for replacing the timing belt on a 1995 chevy lumina apv with the (I think) 3.8L 6-cyl engine?
Mine has about 203,000 miles..I'm not sure when it was last replaced.
thanks!
-Bob
Old 03-14-05, 10:15 AM
your engine uses a timing chain instead of a timing belt there is no set interval for changing that I know of.
Old 03-14-05, 10:25 AM
kb9lfr
Any other considerations??
Any other specifics I should check before going on a long (~2,000 mile vacation) to decrease the chance of getting stopped by a mechanical failure?
(the transmission was replaced with a rebuilt one about 2.5 years ago, so it should still be good). No visible oil consumption (no visible leaks...engine doesn't seem to burn much..it's usually not very low when I check)?
thanks!
-Bob
Old 03-14-05, 10:39 AM
well you should check the belt and hoses and brakes as these are items checked before going on a long trip that often could cause you problems.
Old 03-14-05, 02:02 PM
Check the tires for plenty of tread and check the tire pressure. Don't forget to check the spare tire pressure also. Think about a tune up if one hasn't been done in a few years, might save you on gas. At least make sure the air filter is clean.
