Replace Instrument Panel Lights '95 Explorer
Trevor3x's Avatar
03-14-05, 08:48 PM   #1
Trevor3x
The dash lights are all just about burned out. I can now barely read the speedometer at night! Any suggestions on how to easily remove the dash to install replacement instrument bulbs for a 1995 Ford Explorer? Thank you!!
Bob53's Avatar
03-15-05, 06:27 AM   #2
HI Trevor...I had the same problem and removing the instrument cluster seemed like a big job. Instead I went to the parts store and purchased a three dollar small purple (they had various colors) light that was black plastic facing the driver but a purple light that faces the cluster. I mounted it with a piece of velcro on the sterring column and plugged it into the cigarette lighter port. It lights my dash cluster just great without any reflection to the driver and was really an easy fix. I hope this suggestion helps.
