electrical problem,'92 voyager
Old 03-16-05, 10:43 PM
Question electrical problem,'92 voyager
'92 plymouth voyager 2.5l . dashboard , no lights,no gauge's working . only top left side say's" check gauges" is lit up. all fuses were checked and are ok. any idea's ? thank you.....car has 126,ooo.miles
Old 03-17-05, 02:46 AM
how did you go about checking the fuses just pulled them out and looked at them are did you use a testlight or voltmeter?
I would imagine you will not have power to several fuses and you may want to check the fusible links under the hood along the drivers side inner fender by the washer bottle if any are blown you will need to replace them with the same guage fusible link wire and go from there trying to find what caused it to blow.
