front seal in transmission leaking
Old 03-23-05, 02:46 PM
yankee_29164
I have a 77 Ltd and I just replaced the front seal in the transmission because it was leaking and now about 100 miles later it is back leaking. does anyone have any clue as to why this is leaking again??????
Old 03-23-05, 02:52 PM
If it wasn't damaged during installation the bushing in the pump is probably worn.
Old 03-23-05, 02:56 PM
yankee_29164
is it fixable??
is it fixable and if so how hard and do you know if the pump can be replaced without rebuilding the transmission???
Old 03-24-05, 12:29 AM
Please use the reply button instead of starting a new thread
Yes you can remove and install a new bushing without overhauling entire trans.
Does require knowledge and understanding of trans rebuilding for proper procedures.
Old 03-24-05, 08:46 PM
hopkinsr2's Avatar
Is this trans a "FMX"?? If it is, they had a bad habit of corroding between the trans body (cast iron) & the pump ( aluminum) If not, check the welds on the torque converter & also the bolts that hold the pump to the trans body. A florescent dye may help pinpoint the leak as well Good Luck (R)
