gear lever position indicatior light
Old 03-24-05, 08:07 PM
roland2002
hello,
I have a chevy express van 2001. when i shift into drive or neautral the indicator light for the the position of the lever does not light up or it will light up but go out sporadically. sometimes it will flicker when i use the turn signals although this may be a false indicator because it flickers at random times also. i suspect it to be a loose connection but i would like to know where to start looking for it.
tks for the help
roland in connecticut
Old 03-25-05, 02:52 PM
It's in the cluster itself. You'll have to remove it and disassemble it. Look for a loose/broken solder, or damage to the printed circuit. Or you could take it to an electronics repair center, thats your call.
Old 03-25-05, 05:28 PM
roland2002
indicator light
tks for the quick reply. I am going to get into it this weekend and see what happens.
