Programing Keyfob for GM vehicles
Old 03-27-05, 03:11 PM
alarmman
Does anyone know how to program/learn keyfobs to my 2002 yukon.the dealer wanted 40 dollars just to learn them to the car.
Old 03-27-05, 06:22 PM
To program the key fobs, you will need to take your truck to the dealer or a shop with a Tech 2 scan tool. For resynchronizing the fobs, hold the lock and unlock buttons down at the same time until the locks cycle. Alot of dealers will do this for no charge as a common curteous (sp).
Old 03-27-05, 06:40 PM
hopkinsr2's Avatar
I don't know for sure, but check your owners manual. I've found that some have a routine (cycle key, push lock button etc) printed for the owner to programme keys & fobs & turn features on & off.
Old 03-28-05, 06:50 PM
This should do it
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
You may program up to 4 transmitters, using either of the two following procedures:
Transmitter Programming Procedure (Method 1 - No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation.
