1995 mazda 626 engine
Old 03-30-05, 05:03 PM
tudusta
my engine is kleaking at the cam and crank seals. shop says theres too much pressure built by the piston and rings, id rather overhaul engine than replace seals. is he for real?
Old 03-31-05, 03:11 AM
an engine with to much blowby will leak oil and while you can replace the gaskets and seals they will still continue to leak you should probably get a second opinion, if the engine is very high mileage and is getting worn out then rebuilding or replacing the engine would be the only real fix but get another opinion first.
