86 ford turning over but no fuel
Old 03-30-05, 06:18 PM
Gucci_Owens
I got in and started my truck it started fine then when the idle went down it quit and won't start it turns over. I changed the relay the fuel pump on the frame rail. what else could it be? its not a fuse. oo does the relay need to be grounded
Old 03-31-05, 03:00 AM
if you dont hear the pump run for a second when you turn the key on check the small ground wire coming off of the negative battery cable as this is a computer ground and can cause a no start condition.
also check the inertia switch located inside the vehicle either behind a kick panel or under the dash just above the carpet or floor mat should have a reset button on top of it press down on the button to reset.
