Transmission Whine
Old 03-31-05, 05:32 AM
Transmission Whine
I have a 96 Ranger XLT 5-speed 130K 4 cyl. Just recently I started hearing a low-pitched whine when going 45-50 MPH. Jacked the truck up and checked fluid in differential fine, had play in drive shaft which I think is acceptable, rear brakes fine,finally ran truck through gears with rear jacked off ground and whining came from transmission. Looked up troubleshooting and came upon a possible, could the pilot bearing be starting to go on trans. ?? Any other ideas would be helpful . Thanks
Bill
Old 03-31-05, 07:27 AM
comp's Avatar
it may be,,, does it do it only in 5th ???? try the same speed in 4th,,, if fluid's are old i would change them then re-test
Old 03-31-05, 01:15 PM
I dont see the pilot bearing or bushing making the noise you describe there is sevaral bearings internal to the transmission that could be making noise.
Trackbacks are On
Pingbacks are On
Refbacks are On
